Will 87 Si gauge cluster fit 85 DX?
793 Views 2 Replies 3 Participants Last post by  mullinator
n/m
yes it will fit
and because you are replacing the wiring harness for the fuel injection, you'll have all the correct wires
the mounts are all the same I am pretty sure.
I should mention one thing I've been learning the hard way. It seems many of the connectors on an '85 are not compatible with the '86. So far, 3 of the 5 connectors I've dealt with-- on the throttle body, radiator, and steering column combo switch-- were different. You can just pull the pins out of the connectors and swap them, if you have a matching male-female set. -scott
