No they are illegal
As long as the cat doesn't have a carb exempt # it will not pass the visual inspection part of the smog test, in cali. The cat might pass the sniffer without a problem but the visual you will fail. One way to get around that is to place your stock heat shield around your new high flow cat and this way on the visual they can't see it.
