1 - 17 of 17 Posts
i have a d16z6 and i am looking to get a little higher compression.
i know the pistons for the 90 crx si are a direct fit into the y8 but is it also a direct fit into the z6?
another question, i have bad rings so i am having new rings installed and i though well might as well throw some better pistons in there. what else will i need to upgrade when i have this done, bearings? anything else on the bottom end? how long will i be able to go b4 i have to do anything to the valve train?
thanks in advance.
They should fit, same pin and bore.
Unless you've got a uprated cam the Valvetrain isn't an issue. And the rods are good for 200bhp.
I would never push the limit on stuff like that....I mean....don't we want reliability AS WELL AS performance!?
I know I do.
Discussion Starter #9
hey thanks guys, i would have replied sooner but for some reason superhonda isnt sending me automatic emails about my replies, i dunno?
infinatenexus said:
if your car idles smoothly,,, you don't really want to make Hp.;)
that or you haven't really modified your car... hell even a turbo motor should idle shitty. power and poor idles just go together. it's why i don't like vtec... takes all of the fun out of first gear.
Humm... I am thinking I'll have plenty of fin in first gear when I am done;)
Discussion Starter #14
i had a comp cam and skank2 gear put in my z6 and it still idles smoothly, what else would i need to do to get some shitty idle and mass power ging on? i'll be getting high comp pistons installed soon will that do it?
lol man infinate and i are just doing a little post whoring.
on a car that is equiped with vtec you will have a hard time getting a mild cam to idle poorly. it's one of the benefits to vtec... you can have a good idle with a crazy profile.
Head work,, you need head work;)
1 - 17 of 17 Posts
