Crv awd 5speed, still retaining PS, A/C, Cruise Control,
Engine:
Fully rebuilt Jdm b18c internals undisclosed
Twm itb's 52mm Carbon stacks, currently running ProSeries with 70mm TB and port match till the plenum is done for itbs. Plan on having it as a DD
Custom made 1off RMF style header
skunk2 carbon composite fuel rail
550cc injectors
aem fuel pressure regulator
walbro 255lph fuel pump
MSD SCI with ss blaster coil
cometic head gasket
New oem Honda rings, bearings, gaskets etc.
fluid damper under drive pulley
greddy timing belt
New oem water pump and oil pump
custom Aluminum dual row half radiator with slim fan
Royal Purple lubricants - Engine oil, Trans fluid, diff fluid, oil filter etc.
Street Tuned on s300
My bro did the engine build, motor swap, rmf fab and Tune #JazzBuilt
Will be posting updates
1st morning home
1st Night home already tearing it down
day2 swap in progress
Slammed the next day
TWM's
test fitting and measuring for custom itb plenum
checking if its still breathing :thumbup:
Finished just sitting back and admiring the beauty in it.
on the stand and finished
test fitting rmf's
custom bends for 5speed awd trans
Bling for the swap
ready for initial start-up
Swap done just came back from first drive
Just Cause
