Can a auto wiring harness be used on a 5spd? Reason I'm asking is I can get the wire harness with a motor I'm getting but its out of an auto, but if I can use it that makes things much easier...
You want to use the auto engine harness with a 5sp tranny and 5spd ECU thats fine but you are going to have to wire in reverse lights, because thats the only thing that won't work if you use the auto harness.
