I need to see if it possible to wire the break lights to also work as my turn signal. For instance, with the brakes pressed and turn signal on the one brake light would turn off and on or brighten and dim. Think ya get the picture, if anyone knows how this can be done please fill me in. Think the fuse may need to be changed to a different style maybe.
ehh i dont think you want to go messin with the wiring for brake lights cause it may not be legal.
but what you would have to do is run the brake lights through the turn signal circuit like a paralell so they can also double as brake too, but i think you would get feed back and bad grounds and alot of bugs with this experiment
