Wiring harness schematic required for Alpine 3528 Amp
ive done a search and found nothing, does anyone out there have a wiring harness for a 3528 amp and is able to tell me which is the ground, power, remote etc in the main wiring harness plug? thanks.
Are you referring to the wire harness? Wiring loom is plastic tubing which is used to protect wire runs in the engine bay or passenger compartment. At least that is how the term is used here. I believe the power harness for the 3528 was just a Molex plug. You can rig it yourself if you can find a matching plug at a local electronics store
Or you can contact Pacific Coast Parts Distributor which supplies parts for Alpine.
Alpine Click on support. Part # is 01T70750F01 $14.02 USD
Your a legend! Thanks very much for that:D by chance, you dont ahve access to the harness schematics for the speaker output's do you? cheers:)
Here is the pin out for the speaker harnesses. PM me your e-mail address and I'll send you the .pdf manual for the 3528.
