I have a b16 in a 93 civic dx, and I checked through all the wires the other day and realized that the ***** wire does not run all the way to the ecu, because aparently they didn't wire the dx. Has anyone eles on here have to wire up their own *****? i already ran wires into the car, I just need to hook them up to the ecu. Any suggestions would be great, thanks.
You'll have to get some ECU pins, I suggest going to a junk yard and buying some old ecu connectors and using those pins, run the Vtec Solenoid (the one with only one wire coming off of it, green and yellow) to pin A4, then run the Vtec oil pressure switch Blue wire to pin D6 and just run the other wire to a grounding spot anywhere on the car.
