just wondering see i got a 87 crx and since it does not have springs in front and wanting to drop a little is the kyb gas shocks help lower the car a little or stays the same as oem height.
The shocks won't lower the car any. There should be a ride height adjustment bolt on one end of the torsen bars, you can can it down some. The only bad part about doing that is it will lessen your spring rate, I think there is a company that makes lowering torsen bars for the 1st gen rex if you look hard enough your should be able to find them.
cool deal. i already lowered the car with those torsion bars and the back is pretty high and i want to lower the back but dont want to lower to much. but i will look into a company that makes torsion bars. thanks
