I forgot the damn digital camera when i was installing the new modded shifter. However, it IS installed now, and i have only great things to say about it!
All in all, doing this short shifter install myself (over having the body shop do the swap again) i was able to take my time and do the swap with tender loving care! The shifter is smoother shifting, its at an incredibly comfortable new height, and the 3rd gear synchros seem to be back in alignment.
All from cutting a short shifter down to a lower profile, and adjusting the pivot bolt at the base of the shifter lever!
I highly recommend taking your short shifter to a local metal shop or machine shop and have them grind and cut the height down, and re-cut the threads in with a die cutter.
I will try to get pics of the installed short shifter and the old short shifter that this one replaced.
