Ok an update on my problem with my GSR: I called today and cancelled the appt with the Acura dealer that wanted to charge me $300 for a valve adjustment. He told me that my #1, #3, and #4 cylinders were showing 165-170 psi on the compression check, and that the #2 cylinder was showing about 125 psi. The car is still running rough on idle, and still is NOT smoking. And the malfunction lamp is still going off, which the Acura service guy told me was cause it was reading a misfire on the #2 cylinder.
Now I got to looking in my Haynes Integra manual, and it said if you check the compression and one of the cylinders is about 20% less than the others, AND you have a slightly rough idle, that the exhaust lobe on the camshaft COULD be worn. This sounds like EXACTLY what I have.
Anyone had any experience with this? If this is the problem how expensive is this, and how hard to do is it?
