Not sure if I can upload pic, but here are the mods so far....car is till under construction. I hope to have it completed by the NOPI Mini Truckin/Sport Compact Nats in June...
89 CRX DX
JDM ZC DOHC
89 Integra ECU
DX 5 Speed Tranny w/lightened flywheel (approx 4 lbs.)
Ram PowerGrip Clutch Set (Stage 3)
B&M Short Shifter
Prothene Urethane shifter stablizers
Venom Hi-Flow Injectors
Venom Hi-Flow In Tank Fuel Pump
Venom H-Flow Fuel Rail
Venom Adjustable Cam gears
Venom VCN2000 Nitrous Sys
MSD SCI Ignition Module
MSD Blaster SS Coil
Vitek Ignition Wires
NGK V Groove spark plugs
Prothene Urethane motor mount inserts
Weapon R Dragon Intake System
Weapon R Adustable Fuel Pressure Regulator
Weapon R Pro Circuit Coil Over Springs
Koni Adustable shocks (front & rear)
Powerstop Cross drilled Rotors
VGX Carbon Metallic pads
Goodrich Stainless Steel brake lines
DC Sports Ceramic Coated 4-2-1 Custom header (89 Teg upper/CRX Downpipe)
DC Sports Polished Stainless Steel Cat back Exhaust
DC Sports rear upper strut bar
Neuspeed upper front strut tower bar
Suspension Techniques front and rear sway bars
Kaminari Aerodynamics 88-89 body kit
Aerogear Z3 fiberglass front fenders
Custom made aluminum wing spoiler (discontinued Konig wing)
APC clear corners and bumper lenses
Enkei 17X7 CDR9 wheels (not on car yet - waiting on tires)
And yes, the car is FAST! Not sure of the times yet. Waiting on the track around here to open back up to make some test runs.
