JDM one with 40 K , 30 day 100% warranty for only 875.00/shipped. I accept PayPal ( using your checking,savings,debit,or even credit ) . My ebay username is lilgauge , or I accept Cashiers Checks, Personal Checks ( must clear ) .
I would need to know if it's going to business or residential, and if a lift gate would be needed.
All internal engine parts including: pistons rings, piston pins, crankshaft and main bearings, connecting rod bearings, camshaft and camshaft bearings, timing chain (or belt) and timing gears, intake and exhaust valves, valve springs and seals, and guides, oil pump, push rods, rocker arms and shafts. The engine block, cylinder barrels and cylinder head are also warranted to be free of cracks or distortion.
the engine was imported from Japan,with the 2.0l dual overhead cam non-VTEC engine. It has been compression and leakdown tested on the 4 cylinder engine.
Thanks in advance,
Justin Pickett
Gaige D Motorsports
