i need to know what needs to be done to put the y7 head on a b7 block. i was told about the oil jets, can someone explane to me more about what i have to do.
my friends head is cracked and has no other head to put on it.
You will need to use b7 head bolts except for the top left corner bolt. For that hole you will need a y7 head bolt. Use a y7 head gasket. Should be a decent bump up in compression from the b7. y7(34.6cc chambers vs. the b7 38cc). Should be somewhere between 9.8-10:1 CR. You can get a decent regrind cam from DeltaCam or Exospeed for the y7.
The oil jet is in the top of the block between cylinders 2 & 3. For Y heads and Z heads the oil jet is in the head so you would remove the one in th block or oil pressure will be too high. the Y7 is a good choice for performance without any wiring hassle on an older non-VTEC. It not only raises compression but the valves are larger and the valvetrain easily handles over 7K rpms.
Thanks, I'm sure everyone will appreciate that misinformation. FYI, not ALL D-series parts are compatible. And when their VTEC won't engage due to extreme oil pressure, since you told them to slap it on and go. Older sohc non-VTEC blocks have oil control jets in the block not the head, there are even step-by-step mini-me instructions with pictures on the web, you can see them removing it.
