I have a couple of questions regarding this swap. I did a search and found out that it is best to use an auto Y8 manifold if you plan on keeping your Y7 head and ecu. Would it be possible to use a 5 speed Y8 intake manifold with a stock Y7 ecu and use the Y7 stock throttle body? (throttle body will be ported) Could I use all of the hardware ie, injectors, fuel rail, etc. on the Y8 5 speed manifold? If possible is there anything else that I should be aware of? I have access to a Y8 manifold from a 5 speed and just want to cover all of my bases before the purchase. Thanks in advance!!!
