SUPPOSEDLY weilds more usable midrange power. basically the theory is to move the torque curve around to make a tiny bit more power but alot sooner. and personally after having done this swap. i felt like it was a waste of time. but he is doing it on a y7 they are only torquey (and i use that term lightly) because they have short runners with virtually no plenum. the idea of the swap is to pick up all the mid range that say a y8 without vtec would have. the swap (to me) was pointless. the only thing i liked about the swap i did was the fact that i used a hondata intake manifold gasket.what is the point of this swap?
so basically it's a swap that's a pain in the ass that won't make you any faster?SUPPOSEDLY weilds more usable midrange power. basically the theory is to move the torque curve around to make a tiny bit more power but alot sooner. and personally after having done this swap. i felt like it was a waste of time. but he is doing it on a y7 they are only torquey (and i use that term lightly) because they have short runners with virtually no plenum. the idea of the swap is to pick up all the mid range that say a y8 without vtec would have. the swap (to me) was pointless. the only thing i liked about the swap i did was the fact that i used a hondata intake manifold gasket.
youd be surprised. i had a z6 with a y8 and it saw great low end power i mean d series motors are not impressive na but when you start giving h23 integras a run then they start to surprise you you know. howeever the y7/8 with the z6 manifold from what i hear is a complete waste of time. but then again ive only done a similar swap sooo it may work out ok for himso basically it's a swap that's a pain in the ass that won't make you any faster?
nooo i had similar intake manifold swap on a d series hatch that i just traded off and it was holding next h23 tegs..you have a crx making similar power to an h23 teg. and the teg weighs atleast 400-500lbs more than the crx. of course you'd give it a run for it's money. shorter gearing is what really helps lower power n/a cars if you want better acceleration. prime example is swapping a b18b tranny with an si tranny on a b18b. you'll spank b16's making 20 more whp
you're talking about two tq less cars racing each other. an eg hatch is still light as fuck compared to a teg. especially one with an h23 in it. that's atleast 75 lbs of extra curb weight added to the teg. a stock teg with an h23 would be over 2700lbs. about 2735 lbs to be exact. and d-series eg bubble would be around 2200 lbs.nooo i had similar intake manifold swap on a d series hatch that i just traded off and it was holding next h23 tegs..
i was talking about my hatch and the teg not the rexthe money and time spent on the z6 motor i had went well. and they surprise bigtime when you can do that..
and the crx i have now is just a stock si and a b16 with suspension goodies lol thats it.
