hey guys i have a stock dohc ZC as im in australia, and recently the front and rear engine mounts have come loose, and totally threaded. just wondering if this owuld be upsetting some of the sensors, because its now putting out a 4, 8 and 15 code.
top dead centre, crank, and ingnition sensors, would then engine jumping about a little have caused this? im gettinga b16a soon anyways so its nothing grand to have the zc stay the way it is just a more touble shooter kinda thing.
thanks guys
-dave
sice you are gettting a new motor soon i would reset the ecu and then drive it around and see if the computer says the same troubles are happening. the way i think the comp. works is if a prob happens it stores it in the memory of the comp. even if the prob. is gone. so i would do that and see if those codes come up again. just a thought see what happens good luck.
Discussion Starter · #5 ·
hey guys!! hehe yeah mate! ;) yeah i tried resetting the ecu but then it had the same troubles straight away again... but then the check engine light went off and car drove like new... but the mounts are gone so i think im just gunna rip it out!
thanx for that guys! ill have a look at the connections and shit aswell! thanx
-dave
