Looks great if you have a lot of money and want a Hondata type system for OBD 0. From the website i see many features that look similar to that of hondata systems. However when i downloaded the software i wasnt to impressed. It seemed as if many things i find useful in hondata and crome were not there, some things that are almost downright nessesary. If you want to stay obd0 this is the way to go no doubt. However If you are flexible and would go obd1, then I would take that route instead.
Here is how much my Crome setup cost me:
ECU: $20(i bougt a P09 on ebay for 5 us dollars 20 shipped and converted it for vtec and boost) your price will probably be a lot more, maybe 60-100.
Crome pro: 150
Romulator: 200 (i believe there are cheaper units now)
Max233 adapter: 5 (kit, i built it myself, but the assembled ones cost like 25)
So my setup cost 400(not including my laptop and usb-serial cables), but im obd1 stock so i got out cheaper yours will be more, but from tuning experience obd1 is the way to go.
You will need a conversion harness: 110 from frogenginecontrols.com
And a OBD1 Dizzy for your motor: New cost 180 on ebay.(you can use obd0 injectors as long as you keep the resistor box, its just like putting dsm 450's in an obd1 car and adding the resistor box if you think about it).
So im thinking you would pay about 740 bucks for a completly tuneable system using your "stock" type ecu so that there is no rewiring of the car for an aftermarket system(except the 0bd1 conv), which still isnt bad considering Zdyne wants 695 for thier super pr4 ecu alone and you still have to buy a laptop either way you go. <=That is if you decide to tune yourself, if not save the money on the romulator, crome pro, max233 and other stuff for tuning yourself and spend it at the dyno.
