Polished Valve Covers
Step 1
Start off with 600 (dry) sandpaper on an Electric Palm/Finishing Sander or Sanding Block.* Sand to a smooth surface. i did this step over and over before moving on to step 2. cuz my valve cover is dirty as shit. if yours are like mine, i suggest you do this step long than others.
Step 2
Cut 1000, 1500, and 2000 grit (wet/dry) sandpaper into 1-2" squares.* Then soak in a bowl of water.* Bowl should be one you care a little about.
Step 3
Sand surface with wet sandpaper using varying circular motions.* Sandpaper will slowly loose its grit as time goes on.* Use 1000 (1st), 1500 (2nd), and 2000 (3rd).
Surface will get smoother as time goes on.* Clean cover/area thoroughly.
Step 4
Use a polishing agent to finish surface area.* use NeverDull, Bue Magic Metal Polish, but any polish will work when used as directed.
Your Done!!! Enjoy your new Polished Valve Covers!
Step 1
Step 2
Step 3
Step 4
