Crankshaft
706 views 2 replies 2 participants last post by  2khonda
#1 ·
I have a 96 prelude with h23a1 obd2. the Crank position sensor is located with the oil pump........The h22 doesn't have this. Where can I run this sensors too.... I hears to use the h22 distributor with the Internal coil and then cut the crankshaft sensors then extend the wired to the distributor....is this correct. and where exactly do they go connecte...(what wires in distributor)
I'm using the H23a1 harness but do I need to use the h22 harness to eliminate this sensors
I'm using the h23a1 distributor with the External coil.....Do I need to use the Internal Coil
this swap is pissing me off.....Please help...
#2 ·
ob2 h22s have the crank sensor on the oil pump like yours...sounds like you have an obd1 motor
search obd1 conversion
