MAP Sensor on JDM B16A
2.1K views 2 replies 3 participants last post by  MrV
#1 ·
What's up guys? I recently purchased a '94 JDM B16A SiRII and I was wondering where the MAP sensor is? I know on all other Honda motors it is on top of the throttle body. But on my engine it's not, and there aren't any holes for it or anything??? Does anyone know where is it or is it missing???
Any help is greatly appreciated.
Thanx
Later
#3 ·
JDM B16A2 doesnt have the map sensor mounted on the throttle body, it is mounted on the firewall and has a vacum tube running to the throttle body. So you will need the map sensor that mounts to the firewall or use a throttle body with a mapsensor mounted on the throttlebody.
JDM B16A1 and 2 both have map sensor on the firewall
B16A1 has a 58mm throttle body
B16A2 has a 60mm throttle body
Best thing to do is get a throttle body from a B18C engine as this is 62mm and has the mapsensor on the throttle body;)
